Home » Sponsored » Pi Speakers » Pi midhorn: how thick to be effective?
Re: Pi midhorn: how thick to be effective? [message #75474 is a reply to message #75472] Fri, 08 February 2013 15:25 Go to previous messageGo to previous message
You know, you can really reduce panel thickness with the right bracing. Bracing is usually much more effective because the brace is in compression or tension, whereas the panel being braced is in shear. It's a lot easier to bend a panel than it is to compress or stretch it, so making it stronger by virtue of thickness isn't as good as using braces. Of course, we usually do both.
You can also use constained layer damping, which allows really thin materials to act as barriers. So a thin CSD panel with braces could be used. Just two thin sheets of some rigid material with viscous material in between. The viscous material provides resistance to shear deflection, and so this plus the bracing makes a very solid construct.
Previous Topic: Flanking Subs vs Helper Woofers
Next Topic: 4Pi's Biamped?
Current Time: Thu Nov 05 18:47:34 CST 2026
