Home » Sponsored » Pi Speakers » Why do you not use summed bass for flanking subs?
Re: Why do you not use summed bass for flanking subs? [message #75378 is a reply to message #75377] Tue, 29 January 2013 10:00 Go to previous messageGo to previous message
If the four subs - the three flanking subs and the single distributed sub - were all sent the same signal content, then they would do a good job of modal smoothing throughout the modal range. They would fall into the category of "if you have four subs, it 'almost' doesn't matter where you put them".
On the other hand, if only one or two were sent the same signal content, well, I think that's pretty much self-explanatory.
If there were no limits to budget or contraints on placement, I would probably run a pair of distributed subs in addition to the flanking subs. But the whole distributed subs thing is a matter of "more is better with diminishing returns". So there is improvement just having the one distributed sub in addition to the flanking subs, and depending on content and layout, it may be excellent, no other subs needed.
Previous Topic: Value of L1 on 7Pi schematic?
Next Topic: Anyone Gone From A Planar Type Speaker To 4Pi's
Current Time: Tue Nov 24 18:30:52 CST 2026
