Home » Audio » Speaker » Loose Wire in Car Speaker?
Re: Loose Wire in Car Speaker? [message #75344 is a reply to message #75343] Thu, 24 January 2013 13:57 Go to previous messageGo to previous message
iLoveiPod is currently offline  iLoveiPod
I'm pretty sure I'm in the same boat as you, only it's one of the wires going to the CD player rather than a speaker.
Is it a speaker in a door? If so, you'll probably have to remove the interior door panel for access to the speaker. Then you should be able to just pull the speaker right out and fix the wiring.
Previous Topic: fostex fe166es-r
Next Topic: Realistic Mach One Like Build
Current Time: Wed Nov 04 03:35:47 CST 2026
