Home » Audio » Home Theater » TV Mounting
Re: TV Mounting [message #75335 is a reply to message #75333] Wed, 23 January 2013 19:25 Go to previous messageGo to previous message
The wall-mount I suggested will actually make it much less likely that the television would fall on somebody than if it was just sitting on a stand. The lag bolts that hold the mount to the wall studs are very strong, and will support hundreds of pounds, way more than the televison weighs. And the television is firmly attached to the mount with large screws, again, able to support hundreds of pounds. So once it's up, it will stay there.
Previous Topic: Home Theater Sound Biases
Next Topic: Visual Symmetry vs Sound
Current Time: Sun Oct 04 12:27:27 CDT 2026
