Home » Audio » Speaker » Tuning below Fs with JBL 2226H?
Tuning below Fs with JBL 2226H? [message #75301] Mon, 21 January 2013 03:53 Go to previous message
Omholt is currently offline  Omholt
I'm considering building two bass units in vented boxes for a two channel setup. I want something that can be crossed over in the 200-250 Hz region. The JBL 2226H is considered a fine driver for midbass.
At the same time I would like good ouput down to about 25 Hz.
The plan would be to start with two stacked drivers on each side and increase with three or four later if it's needed.
If the cabinet is large enough, using several drivers on each side and I have enough watt, is tuning to around 25 Hz problematic and a compromise? The Fs of 2226H is 40 Hz.
Is it better to use a driver with lower Fs? What would be recommended in that case.
Previous Topic: Open Baffle Speakers
Next Topic: Desktop PC computer speakers
Current Time: Fri Nov 13 09:22:20 CST 2026
