Home » Sponsored » Pi Speakers » 4 PI by Andy
| Re: 4 PI by Andy [message #75293 is a reply to message #75291] |
Sun, 20 January 2013 17:11   |
There is no downside to lining the cabinet walls with acoustic damping material. I've had best luck with R13 insulation. So feel free to add it.
If you're concerned with midrange, you can also install a sheet that spans the cross-section. It seems to work best at midrange frequencies when the cross-section sheet is between woofer and port.
But if you're going to use it as a prosound sub, I would probably discourage the cross-section sheet because there's a lot of air moving at full tilt. A prosound sub should be purpose oriented, and big boxes with big ports should be used without anything impeding airflow between them.
A box with 36" internal dimension will have a standing wave at 180Hz. It will have others too, but the longest dimension sets the lowest axial mode. So that's the one to watch.
I wouldn't be comfortable using that as a flanking sub unless I measured it and knew it wasn't making any artifacts all the way up to 200Hz.
And that's really the issue here - I'm not saying standing waves will create response anomalies, I'm saying they might. If signals are presented to a woofer in a cabinet with at least one 36" dimension, then standing waves will exist inside the cabinet. If the woofer or port sits on a pressure node, then those standing waves will cause a response peak. So you would probably want to make sure the port and woofer are positioned in such a way that response is good. That's what we do when designing the mains too, or at least, that's what I do. It's why I tell people to be careful when contemplating baffle changes and mods.
This is basically a measurement thing. Measure the box and look for ripple above 150Hz. If you don't see any, then there's nothing to worry about. If you do see ripple, then you can either change the baffle and put the port and/or woofer in a different location, or you can limit the frequency range, and don't send signals at or above the anomalous range. Low-pass it below the frequency where it gets wonky.
4 PI by Andy
By: mantha3 on Wed, 03 October 2012 07:48
Re: 4 PI by Andy
By: mantha3 on Wed, 03 October 2012 08:04
Re: 4 PI by Andy
By: mantha3 on Wed, 03 October 2012 12:48
Re: 4 PI by Andy
Re: 4 PI by Andy
By: mantha3 on Wed, 03 October 2012 15:56
Re: 4 PI by Andy
By: mantha3 on Wed, 03 October 2012 16:22
Re: 4 PI by Andy
Re: 4 PI by Andy
By: mantha3 on Wed, 03 October 2012 17:52
Re: 4 PI by Andy
Re: 4 PI by Andy
By: mantha3 on Wed, 03 October 2012 18:00
Re: 4 PI by Andy
Re: 4 PI by Andy
By: mantha3 on Thu, 04 October 2012 07:24
Re: 4 PI by Andy
By: mantha3 on Sat, 03 November 2012 09:26
Re: 4 PI by Andy
By: mantha3 on Sat, 03 November 2012 09:30
Re: 4 PI by Andy
By: zheka on Sat, 03 November 2012 14:56
Re: 4 PI by Andy
By: mantha3 on Sat, 03 November 2012 16:39
Re: 4 PI by Andy
Re: 4 PI by Andy
By: mantha3 on Sun, 04 November 2012 16:14
Re: 4 PI by Andy
By: mantha3 on Sat, 10 November 2012 07:49
Re: 4 PI by Andy
Re: 4 PI by Andy
By: mantha3 on Sat, 10 November 2012 11:04
Re: 4 PI by Andy
By: zheka on Sun, 20 January 2013 09:25
Re: 4 PI by Andy
Re: 4 PI by Andy
By: zheka on Sun, 20 January 2013 13:41
Re: 4 PI by Andy
Re: 4 PI by Andy
By: mantha3 on Thu, 18 April 2013 13:01
Re: 4 PI by Andy
Re: 4 PI by Andy
By: mantha3 on Thu, 18 April 2013 19:55
Re: 4 PI by Andy
By: mantha3 on Thu, 18 April 2013 19:58
Re: 4 PI by Andy
Re: 4 PI by Andy
By: mantha3 on Fri, 19 April 2013 11:57
Re: 4 PI by Andy
Re: 4 PI by Andy
By: zheka on Sat, 10 November 2012 13:55
Re: 4 PI by Andy
By: zheka on Sat, 10 November 2012 14:00
Re: 4 PI by Andy
Re: 4 PI by Andy
By: mantha3 on Sun, 11 November 2012 08:15
Re: 4 PI by Andy
Re: 4 PI by Andy
By: mantha3 on Wed, 14 November 2012 19:59
Re: 4 PI by Andy
By: mantha3 on Fri, 07 December 2012 08:28
Re: 4 PI by Andy
By: zheka on Fri, 07 December 2012 08:49
Re: 4 PI by Andy
By: zheka on Sun, 20 January 2013 14:01
Current Time: Sat Nov 07 00:01:54 CST 2026
