Home » Sponsored » Pi Speakers » Subwoofers vs budget... where do you draw the line?
Re: Subwoofers vs budget... where do you draw the line? [message #75288 is a reply to message #75283] Sun, 20 January 2013 01:22 Go to previous message
j0nnyfive is currently offline  j0nnyfive
Ah, I get it! The pool analogy helps! And the distinction between coarse and dense... I tend to run across discussions that over-simplify the situation (like "interference bad, no interference good"). But, in a room, you can't help but to have SOME interference... so if you purposefully create interference everywhere, then it becomes effectively nowhere. Smile Thanks!
Now I can explain it better to my friends. lol
Previous Topic: Old veneer method, new to me...and it worked!
Next Topic: 4Pi and 7Pi Plans
Current Time: Tue Oct 20 20:57:09 CDT 2026
