Home » Sponsored » Pi Speakers » Subwoofers vs budget... where do you draw the line?
Re: Subwoofers vs budget... where do you draw the line? [message #75257 is a reply to message #75256] Tue, 15 January 2013 18:46 Go to previous messageGo to previous message
What you need to do is connect to the preamp level outputs on your receiver. Sometimes those are used to connect equalizers and sound processors. The preamp level signal is sent to the subwoofer amp through a low-pass filter. Plate amps usually have low-pass filters built into them.
Previous Topic: Old veneer method, new to me...and it worked!
Next Topic: 4Pi and 7Pi Plans
Current Time: Fri Nov 06 05:22:49 CST 2026
