Home » Sponsored » Pi Speakers » Looking for some Pi advice for theater ... (4pi vs 7pi)
Looking for some Pi advice for theater ... [message #75235] Mon, 14 January 2013 09:11 Go to previous message
AlphaG is currently offline  AlphaG
So I did spend a fair bit of money on a theater layout and am very happy with it. The speakers are specified to be behind a screen wall. I would like to use some of my DIY skills to make the LCR speakers and to that end I have done a lot of reading, multiple forums.
I have come to the conclusion that I cannot design a speaker from the ground up myself, but fortunately the Pi's are available as established plans.
http://i592.photobucket.com/albums/tt6/dipanlokenpatel/floorplan_zpsdfed5976.jpg
So I did some more reading, including Wayne's white paper. Seems like the optimal solution is to use cornerhorns for left and right, but I would like some opinions on whether this is possible in the space. I don't mind putting the LR speakers out in front of the screen wall if they are in the corner. To that end, I can eliminate the front pillars in the room to make a smoother wall-waveguide. In this instance, I can build a 4Pi for center channel use.
The other option is building 3 x 4pi's. Baffle mounting them could prove problematic because of the limited space behind the screen wall, and would be more complicated. And if I used them with "flanking" subs, I would have to build more subs. I already have a plan to build a large front subwoofer (and have some of the equipment for this) and have two Peerless XLS subwoofers that I planned to use in back surround pillars as "distributed" subs. If I eliminate the front pillars, I would eliminate the back pillars and perhaps mount these reinforcing distributed subs in the floor.
Finally, I do feel somewhat hesitant to deviate too much from the specified plan. Hopefully I can find an optimal setup that I'm comfortable with, and one that let's me DIY it with success.
I'm glad I found this resource. Thanks for the help!
Previous Topic: Pi 1 plans please
Next Topic: Old veneer method, new to me...and it worked!
Current Time: Tue Sep 22 07:16:45 CDT 2026
