Home » Audio » Group Build » Microphone Interface
Re: Microphone Interface [message #75142 is a reply to message #75139] Fri, 04 January 2013 15:42 Go to previous message
That's pretty cool, Bruce. Lots of capacitance in there with good long RC time constants to make the supply smooooth. Gives a good voltage too, just right for standard IEC 61938 phantom power.
On a semi-related note, the little electret condenser microphones so commonly used by DIYers also need power supplied to them, although it isn't quite as high a voltage requirement as used in (any flavor of) IEC 61938. The electret capsules usually need 2-10V. I sometime use AA batteries for electret condenser power, which also provides good noise immunity. This is a little preamp circuit I use, which provides phantom power for the little microphone capsules:
Previous Topic: Two new valve based projects
Next Topic: IR Remote Control
Current Time: Sat Nov 07 05:02:37 CST 2026
