Home » Sponsored » Pi Speakers » Flanking Subs vs Helper Woofers
Re: Flanking Subs vs Helper Woofers [message #75081 is a reply to message #75080] Fri, 28 December 2012 17:46 Go to previous messageGo to previous message
Absolutely. That's precisely what you want to do. The more bass sound sources there are, the better. So the two flanking subs become two of the four distributed multisubs at low frequencies.
The summed LF output is only being run to the distributed subs, of course. The flanking subs are getting a low-passed copy of the mains they are flanking. So there may be sounce material where each flanking sub has different signal content. In this case, the blend will be different than if all subs got the same signal. But then again, if the flanking subs received truly different signals, they could be uncorrelated in the source material, itself. However, in practice, this is rarely the case. Usually the LF content of both left and right front channels is nearly the same. It is pretty much summed in the mix, in most cases.
Previous Topic: Notes on Ironing Veneer, Using Watco and ... a distress signal?
Next Topic: Pi midhorn: how thick to be effective?
Current Time: Tue Oct 20 17:58:32 CDT 2026
