Home » Audio » General » PC to Smartphone
Re: PC to Smartphone [message #74959 is a reply to message #74956] Sat, 15 December 2012 19:35 Go to previous messageGo to previous message
timron is currently offline  timron
I think there are several ways to transfer music from your PC to your phone. For one, you could hook a USB cable up between the two and your PC should read the smartphone like any other external storage device. Then you should be able to just "drag and drop" the files. You could also transfer the files using an SD card, if your PC has an SD card reader built-in. The SD card would function the same way a flash drive would - you put the card in the computer, put the music on the card, and then put the card in the phone.
Hope this helps!
Previous Topic: Car DVD Players
Next Topic: How Many Amplifiers are in Your Listening Room Today
Current Time: Thu Nov 12 07:16:02 CST 2026
