Home » Audio » LSAF » LSAF 2013
Re: LSAF 2013 [message #74749 is a reply to message #74747] Thu, 06 December 2012 08:38 Go to previous messageGo to previous message
Hi Shane, It's on my bench now in progress. General info is push pull 6L6WXT+ (Sovtek higher capacity version of the 6L6GC) output tubes for about 25 watts class AB1. Could use EL34s, KT77s and others just as well though for nearly the same output. Driver is 12AU7 via a interstage trannie. Input stage is a 12AX7 (SRPP) followed by a tone stack and another 12AX7 for gain. Built on the head amp style chassis (about 7 X 17 inches). It should be ready to test in a month or so. I am putting input / output loop connections for effects but at present don't plan on building them into the basic amp. it should work quite well as either bass or lead.
Previous Topic: LSAF 2012
Next Topic: DIY Projects At LSAF
Current Time: Mon Nov 30 10:52:46 CST 2026
