Home » Sponsored » Pi Speakers » Flanking Subs vs Helper Woofers
Re: Flanking Subs vs Helper Woofers [message #74658 is a reply to message #74657] Thu, 29 November 2012 14:58 Go to previous messageGo to previous message
If flanking subs are designed to address boundary interactions and room modes only in the 80Hz-200Hz region, can "mid-bass" bass-reflex modules with high efficiency pro-drivers be used instead of full fledged subwoofers designed to go much lower?
The sub channel signal would still go through "conventional" multisub.
What do you think?
Previous Topic: Notes on Ironing Veneer, Using Watco and ... a distress signal?
Next Topic: Pi midhorn: how thick to be effective?
Current Time: Fri Nov 06 00:24:14 CST 2026
