Home » Sponsored » Pi Speakers » L/C/R placement and toe-in (aggressive toe-in for the L/R,what to do with the center channel?)
Re: L/C/R placement and toe-in [message #74574 is a reply to message #74559] Sun, 25 November 2012 10:25 Go to previous messageGo to previous message
That's right, provided your SPL requirements are maintained, you can stretch the L/C/R arrangement as wide as your screen requires. That is really the size limit on something like this - as the room grows larger, there comes a point where the speakers don't provide enough output. Then you would need a different configuration. But as long as your SPL requirement is met, you can go wide with the left and right front mains. This assumes you're using a center channel though - I'd say the limit for a realistic phantom center is about a twenty to thirty foot spread.
Previous Topic: My 4pi project
Next Topic: 3Pi Subwoofer
Current Time: Fri Nov 06 01:52:31 CST 2026
