Home » Audio » Home Theater » Not What I Thought It Would Be (1000 Watt Speaker System)
Re: Not What I Thought It Would Be [message #74572 is a reply to message #74569] Sun, 25 November 2012 09:59 Go to previous messageGo to previous message
The power rating of a speaker only tells you how much power it can handle before damage. Its sensitivity rating tells you how loud it is. Sensitivity is a measure of efficiency, in that it tells you how much sound is produced at a specific drive voltage or power level. Typical sensitivity ratings are 93dB@1W/1M or 93dB@1M/2.83v. These examples are interpreted as meaning the speaker produces 93dB when measured one meter away given one watt or 2.83 volts, respectively.
Previous Topic: Professional installation or DIY
Next Topic: Problem With Video Out
Current Time: Fri Nov 06 23:46:07 CST 2026
