Home » Sponsored » Pi Speakers » L/C/R placement and toe-in (aggressive toe-in for the L/R,what to do with the center channel?)
Re: L/C/R placement and toe-in [message #74559 is a reply to message #74558] Sat, 24 November 2012 20:05 Go to previous messageGo to previous message
So the mains would never be too wide as long as with, say, 45 degree toe-in, the axes will cross in front of the listening position? This would allow for potentially very wide angles, significantly wider than what's normally recommended for conventional loudspeakers (20-30 degrees from the center to one of the mains).
I currently have mine at slightly more than 30 degrees, the image is very solid. As I said, I had been running phantom center without any issue. The only concern is that some recordings have a single instrument panned wide (probably wrong terminology here) and then it sounds weird. For example it is difficult to get used to acoustic guitar that sounds wider than the room. I am not sure if this is a symptom of the mains set too far apart or a bad recording.
Previous Topic: My 4pi project
Next Topic: 3Pi Subwoofer
Current Time: Fri Nov 06 01:52:35 CST 2026
