Home » Sponsored » Pi Speakers » 4Pi measurements
Re: 4Pi measurements [message #74364 is a reply to message #74272] Sat, 03 November 2012 19:27 Go to previous messageGo to previous message
thatsnasty is currently offline  thatsnasty
zheka wrote on Fri, 26 October 2012 21:51
I wish mine were as well built as BigMouthinDc's Wink I probably made all the usual rookie mistakes and than came up with some more. On the bright side, I will keep the speakers behind the screen so the looks are not all that important.
I did not have a chance to listen to them in any meaningful way. And, for reasons beyond my control, I won't be able to for at least another week. the suspense is killing me but there is nothing i can do...
BTW, I'd gladly help you with measurements if you'd like, as long as you keep in mind the limitations of my gear and expertise.
I appreciate it! I'll definitely be posting when I get them finished. I'm off tomorrow so maybe they'll be done then.
Glad it was just the Zoebel.... I was debating soldering it to the X-over board when I attached them but didn't bother because the clip leads fit really snug.
Previous Topic: 3 Pi Plans
Next Topic: B&C DE250 question
Current Time: Sat Nov 07 05:42:55 CST 2026
