Home » Audio » Craftsmen » 2pi build question (insulation)
Re: 2pi build question [message #73870 is a reply to message #73869] Wed, 19 September 2012 20:17 Go to previous messageGo to previous message
I like using regular wood glue to hold the insulation. I've tried staples - sure goes faster - but then there's always the risk of one coming loose and rattling inside. So I've long opted for a liberal meandering bead of white glue. Holds it in place just fine.
Also, I would stick with R11 and forget about the other stuff. The fiberglass insulation works well and most of the other material people try really doesn't. Put a course metal grille mesh over the port of you're worried about curious hands or critters getting in there.
Previous Topic: Connecting Cables for dummies
Next Topic: Finally Happy With DIY TT
Current Time: Wed Nov 25 06:46:00 CST 2026
