Home » Sponsored » Pi Speakers » 4pi Dinner Theater Update
Re: 4pi Dinner Theater Update [message #73835 is a reply to message #73175] Sun, 16 September 2012 19:58 Go to previous messageGo to previous message
I might have asked this question before, but I cannot find nor remember the answer. Aesthetically, the twelve 1pi surround speakers will look better installed horizontally rather than vertically. Is there any issues with them being installed this way? If not, should I install them with the tweeter toward the screen, or the woofer toward the screen?
Any thoughts on how to acoustically treat this space in light of the fairly "open ceiling" concept employed in which the rafters are largely exposed with very thick open cell spray foam (painted black)? In case it should matter, the floor will be 3/4" acacia hardwood flooring.
Previous Topic: Insulation inside of speaker: Spray Foam?
Next Topic: Low Volume Speaker
Current Time: Thu Nov 05 22:09:57 CST 2026
