Home » Sponsored » Pi Speakers » A month away
Re: A month away [message #73586 is a reply to message #73585] Tue, 14 August 2012 08:09 Go to previous messageGo to previous message
Yup, that will be an unreal system for sure. Lots of wattage! Be careful with the volume knob when this is all hooked up!
One thing I have that you may think about.
I have Cable TV with a Digital package. I've had dish too. The converter boxes suck (IMHO). I got a Decware ZSTAGE for about $600 that you can buy with a balanced attenuator. This works as a buffer to help push the signal from the weak converter and you have a little boost should you want to get a bit stronger signal by using the attenuator. The ZSTAGE runs a 12au7 tube. This is basically the type of output stage you wish they had in these boxes. You might like the tube up front on the way into the system to warm things up... Or not.
Just a thought as you have everything you need.
Keep us posted on what you think in the end.
Previous Topic: 7 pi plans
Next Topic: 1 and 2 Pi Plans
Current Time: Fri Oct 16 14:27:49 CDT 2026
