Re: 4 Pi Home Theater Build [message #73217 is a reply to message #73140] Fri, 06 July 2012 12:36 Go to previous messageGo to previous message
blacklabel0730 wrote on Tue, 26 June 2012 14:52
Check out http://www.foobar2000.org/ It will play any format. It is free, and uses very little memory to run. I switch between that and windows media player. The updated version really does a good job.
I am running http://www.asus.com/Multimedia/Audio_Cards/Xonar_Essence_STX/
for my sound card with RCA cables straight from my PC to my pre-amp and play mostly .flac files. It is slightly compressed but the sound quality is very impressive.
Not sure if that helps you at all, but good luck.
Thanks I will give it a shot. I ordered the Audioengine W-3 wireless transmitter (cd quality DAC, not high res) to send from my computer to the stereo without using the internet (which is not so good here in Cambodia) or wires (which are fine here, but I don't want them running across the room).
VIRIBUS MARI VICTORIA
Current Time: Sat Nov 21 19:48:03 CST 2026
