Re: 4 Pi Home Theater Build [message #73140 is a reply to message #70252] Tue, 26 June 2012 14:52 Go to previous messageGo to previous message
Check out http://www.foobar2000.org/ It will play any format. It is free, and uses very little memory to run. I switch between that and windows media player. The updated version really does a good job.
I am running http://www.asus.com/Multimedia/Audio_Cards/Xonar_Essence_STX/
for my sound card with RCA cables straight from my PC to my pre-amp and play mostly .flac files. It is slightly compressed but the sound quality is very impressive.
Not sure if that helps you at all, but good luck.
Current Time: Sat Nov 21 19:47:45 CST 2026
