Home » Sponsored » Pi Speakers » 4 Pi Design Questions
| Re: 4 Pi Design Questions [message #72895 is a reply to message #72892] |
Sat, 02 June 2012 10:30   |
The measurement above 200Hz is pretty much the same as a standard four π loudspeaker when measured in this manner. And yes, frankly, that's a very good chart. But below 200Hz, it's ambiguous because only room modes can be seen. That's where you would expect most changes due to the box modification to manifest themselves.
This brings us to the hypothetical question, which is, "How much does it matter?" My concern about box mods is always that they might make ripples in the midrange due to internal standing waves. But as long as they're all below the modal range, one might question how much they matter. If we use flanking subs to mitigate midbass and lower midrange anomalies, they'll tend to smooth that range, whether caused by standing waves inside the box or reflections outside, in the room. Still, my take is the less anomalies we can introduce, the better. Less problems to mitigate.
And of course, if we're using subs, we don't need the extra extension the larger box gives, and leaving it stock eliminates the possibility of introducing midrange ripple. The room is dominant below 200Hz, and the biggest peaks and valleys are from standing waves in the room, not in the loudspeaker box. So truly, the best approach is to use multisubs (flanking and distributed) to smooth this range, which will provide both extension and modal smoothing.
My conclusion is this: Since the mods have not introduced any additional ripple above 200Hz, I'd call it "verified". That's the main thing we're looking for here. We don't want any midrange ripple from internal standing waves. Of course, we can't see what it might be doing below 200Hz, but indoors, that almost doesn't matter.
By: mantha3 on Sat, 02 June 2012 08:56
By: mantha3 on Tue, 19 June 2012 07:52
By: mantha3 on Mon, 25 June 2012 17:15
By: mantha3 on Fri, 31 August 2012 15:13
Cabinet design, port placement and internal standing waves
By: mantha3 on Fri, 31 August 2012 18:39
Re: Cabinet design, port placement and internal standing waves
Current Time: Thu Nov 05 13:37:00 CST 2026
