Re: IR Remote Control [message #72835 is a reply to message #72822] Sun, 27 May 2012 15:39 Go to previous messageGo to previous message
Thanks, Wayne. Putting together the parts order.
I will be utilizing this along with the Pass Hypnotize.
After reading your very complete info I will put together a separate supply so the IR remote can stand by without powering the entire Pre. I'll then run a relay to provide switched power for the rest, as your IC provides for.
I intend to duplicate all IR functions with momentary switches on the front panel, with indicator LEDs for channel and VUs.
If it all goes up in flames I promise to document it for entertainment purposes.
You know, this chip-set you designed nailed exactly what I have been trying to do with this preamp build. Uncanny. Fantastic. I hope I can get it together.
Thanks again.
Current Time: Sat Nov 07 04:49:56 CST 2026
