| Re: Frequency response question [message #72697 is a reply to message #72693] |
Sat, 12 May 2012 10:39   |
The measurements are all with upgraded drivers. The difference in amplitude response between the two midwoofers isn't all that great, actually, so there's nothing to see there. The biggest advantage the upgraded midwoofers have is their shorting rings, which help maintain magnetic linearity. That doesn't show up in a frequency response graph, although it does show up in distortion measurements.
The tweeters are a different story. The DE250 is noticeably smoother, and also reaches higher. They're the same up to about 5kHz, but above that, the DE250 remains essentially flat while the PSD2002 has a 3dB bump at 9kHz. That's not terrible by any stretch of the word, and some might even like it better. I've seen compression drivers with more than twice this much peaking in that same 10kHz area. But still, the DE250 is smoother and more extended above 10kHz.
