Home » Sponsored » Pi Speakers » 3Pi Subwoofer
Re: 3Pi Subwoofer [message #72643 is a reply to message #72641] Wed, 09 May 2012 13:42 Go to previous messageGo to previous message
Yes, it's my PI-12 woofer, an OEM version of the LAB12 machined to fit the cooling plug. For the three Pi subs, you could use either driver just as well.
I'm using a pair of those Selectronic 50W Class-A FET amps. Plate amps work great too, and are probably more convenient 'cause they bolt on the back.
I use my little passive preamp - that remote control circuit I made for the DIY and kit amp crowd - and split off the outputs to the amp for the mains and to the crossover for the subs.
Previous Topic: L/C/R placement and toe-in
Next Topic: Which Pi for me?
Current Time: Fri Nov 06 01:43:18 CST 2026
