Home » Sponsored » Pi Speakers » The right waveguide (Decision process)
Re: The right waveguide [message #72599 is a reply to message #72598] Mon, 07 May 2012 15:32 Go to previous messageGo to previous message
As much as I like the Econowave concept, which is a derivative of my three Pi and four Pi loudspeakers, it is no match for constant directivity cornerhorns. The problem is not every room has the right corners. So for rooms that can't support constant directivity cornerhorns, a set of three Pi or four Pi main speakers with flanking subs is the next best thing.
The SEOS waveguides look really nice. In fact, I considered using them for a while. However, on closer inspection I found the SEOS12 is much too shallow, being only 3.5" deep. This doesn't provide enough acoustic loading, and the source location isn't right. In fact, a horn this short will be reactive in the passband so the source location will appear to shift. It will also suffer excessive ripple, and possibly higher distortion. Further, the flare profile isn't purely oblate spheroidal, most of it is a secondary flare, an arbitrary radius. So even though it's a pretty shape, it's not the right shape. At least not for me.
Previous Topic: 1/2 PI Needed, a question for Wayne
Next Topic: 4pi vs 3pi plans
Current Time: Thu Nov 19 14:41:04 CST 2026
