Home » Audio » Silicon Valley » Bass Boost
Re: Bass Boost [message #72159 is a reply to message #72151] Sun, 15 April 2012 21:42 Go to previous messageGo to previous message
Hi, I agree that it can be useful, but I don't use any. I usually find that if you do boost the bass it is because something is deficient. Confused Either in the system or the source material. In the system it ought to be fixed if you can as it will influence all music that is reproduced. If it is in the source material then there are a number of possibilities. One it was intended to be that way (OK), second it is a crappy rendition (not OK and I generally won't listen to it), third is was a legacy recording and might benefit from such assistance (kind of OK). In the last case I can see a positive benefit the others no. The question in general begs the whole issue of tone controls, processors and other enhancement devices. IMHO, if you like them and find them useful, great. If you don't like them, also great. Smile
Previous Topic: Acoustic Research amp
Next Topic: Comparing two amps
Current Time: Sun Oct 04 10:20:54 CDT 2026
