Home » Audio » Thermionic Emissions » Under-Biasing Output Tubes
Re: Under-Biasing Output Tubes [message #71879 is a reply to message #71705] Thu, 22 March 2012 14:30 Go to previous messageGo to previous message
SASAudioLabs is currently offline  SASAudioLabs
I have found that as the idle current lowers from class A towards class B, at some point the sound will start to be perceived as leaner.
With that said, class AB is not a problem if one biases towards descent values, not close to class B.
From .45 to .43 is most likely a couple of ma, and is not going to make any difference in longevity. However, I would check the sonics and see if .5 or higher would be perceived differently with the KT-88s. Set for the best sound. (Always be sure the power tranny does not overheat.)
Cheers.
Previous Topic: Poddwatt - First Posting of a Project Link
Next Topic: Preamp suggestions
Current Time: Sat Oct 17 07:25:20 CDT 2026
