Home » Sponsored » Pi Speakers » H290 bumps / texture inside of horn - ok to sand down to smooth?
Re: H290 bumps / texture inside of horn - ok to sand down to smooth? [message #71776 is a reply to message #71772] Wed, 14 March 2012 21:23 Go to previous messageGo to previous message
Yes, it's fine. Sand away!
The riser marks are the big bumps on the face. The little goosebumps you're talking about are just texture, a form of finish that hides surface irregularities. The riser marks are actually formed where the plastic is injected into the mold. Both can be finish-sanded smooth. Just be careful and don't go so far that the throat opens up. Only take off enough to remove the texture and make 'em smooth.
Previous Topic: Center Channel with 6pi Corner Horns
Next Topic: Let's talk about 4Pi Speaker Stands =p
Current Time: Tue Nov 03 11:40:15 CST 2026
