Home » Audio » General » Banana plugs for 4 way binding posts (Can the wire be soldered in?)
Re: Banana plugs for 4 way binding posts [message #71723 is a reply to message #71719] Sun, 11 March 2012 13:48 Go to previous messageGo to previous message
Wayne Parham wrote on Sat, 10 March 2012 16:25
The problem is one of elasticity verses malleability. Clamping pressure requires elasticity. If the material deforms, then it sort of "bleeds off" clamping pressure. So you're up against that. Copper isn't elastic at all - It's way down there with nickel and aluminum.
I like using bananna plugs or spade lugs. Bananna plugs have springs made of a material that is elastic plated with an electrically conductive metal that doesn't oxidize. That allows clamping pressure from the elastic base material. If a screw connector is desired, spade lugs will provide the same sort of thing - an elastic base metal plated with an electrically conductive surface metal. Tightening down on the spade lug provides clamping pressure without deformation.
If the banana plug uses pressure against the copper, isn't that the same situation? That's why I was wanting to solder the wire to the banana plug.
Previous Topic: Subwoofer Pre-amp out vs. Speaker Line Out and Lighting
Next Topic: How is a subwoofer at this price possible?
Current Time: Wed Nov 04 01:16:26 CST 2026
