Home » Sponsored » Pi Speakers » Audition in Austin
Re: Audition in Austin [message #71677 is a reply to message #71676] Tue, 06 March 2012 08:02 Go to previous messageGo to previous message
I apply 10ft/lbs. It compresses the lock washers, and then maybe about a sixteenth of a turn more. It's really easiest to do with an open end wrench.
Hey, did you use the two opposing studs/nuts to attach the driver to the horns? Or did you use three? I ask because I've done a ton of these and never had to remove any material. But I know some people do feel the need to remove material to access the bolts. Seems like they are all using the three bolt holes, which are uncomfortably close to the support structures.
Previous Topic: 4pi vs 3pi plans
Next Topic: 4pi Commercial Dinner Theater Build
Current Time: Tue Oct 06 19:09:06 CDT 2026
