Home » Sponsored » Pi Speakers » Audition in Austin
Re: Audition in Austin [message #71676 is a reply to message #66232] Tue, 06 March 2012 05:51 Go to previous messageGo to previous message
I didn't care for the glossy shine on the horns so I took some steel wool to them to tone it down. They look much better now.
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4002.jpg
I wittled away at the horn bolt openings with a razor knife for some time getting the nuts on the bolts. Finally dug out a sanding wheel dremil attachment and made easy work of it on the second horn.
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4003.jpg
How tight do you attach the compression drivers, just compress the lock washers??
Previous Topic: 4pi vs 3pi plans
Next Topic: 4pi Commercial Dinner Theater Build
Current Time: Tue Oct 06 20:10:04 CDT 2026
