Home » Sponsored » Pi Speakers » Insulation inside of speaker: Spray Foam?
Insulation inside of speaker: Spray Foam? [message #71596] Wed, 29 February 2012 20:41 Go to previous message
Would low pressure flexible polyurethane foam insulation be an appropriate substitute for the fiberglass insulation you recommend be installed inside the 1pi enclosure?
I know, I know...why can't this guy just doing it like the instructions say. Why must he poke the bear all of the time Wink
http://images.lowes.com/product/converted/074985/074985004803xl.jpg
Previous Topic: 2Pi Tower Plan
Next Topic: 4pi Dinner Theater Update
Current Time: Thu Nov 05 23:02:05 CST 2026
