Home » Sponsored » Pi Speakers » 2 Pi studio in 3 Pi enclosure
Re: 2 Pi studio in 3 Pi enclosure [message #71549 is a reply to message #71548] Mon, 27 February 2012 10:30 Go to previous messageGo to previous message
My standard reply is "I wouldn't do it." The reason is I have spent so much time optimizing and testing the designs. When you modify them, you are throwing away all that R&D time. That is by far the most expensive and important factor, and untested modifications make it moot. When you make mods, you're back to an untested collection of parts in a box.
With that (somewhat strong) disclaimer, I would say that if you put the midwoofer and port in the same position, at least then I would have guarded optimism that the internal standing waves would line up the same way. There is some comfort in that, because I would assume there would be no lower midrange ripple from unwanted standing waves.
But still, I would suggest that you stick with the plans unless you have time and inclination to do acoustic measurements and verify that your mods work well.
Previous Topic: Surround Sound With TV Over Fireplace
Next Topic: Grills for your 4pi? 1pi?
Current Time: Tue Nov 03 19:40:43 CST 2026
