Home » Sponsored » Pi Speakers » 4 Pi - Horn to middle of baffle?
Re: 4 Pi - Horn to middle of baffle? [message #71349 is a reply to message #71303] Fri, 10 February 2012 19:28 Go to previous message
The Class D Audio series digital amplifiers are available as kits or completed units and should fit your need for high performance low cost with balanced inputs. The amplifiers can include gain (volume) controls that will allow you to trim levels as desired. Other options are more expensive unless pre-owned equipment or home theater receivers are considered.
Previous Topic: 18mm Baltic Birch for 1pi: Quick Question
Next Topic: Powering my PI Speakers
Current Time: Mon Nov 02 17:54:56 CST 2026
