Home » Audio » Room Acoustics » Ceiling?
Re: Ceiling? [message #70867 is a reply to message #70862] Fri, 06 January 2012 19:05 Go to previous messageGo to previous message
The ceiling is probably the most important room boundary to treat. We're used to hearing sounds from all around us, so lateral reflections aren't unnatural. Same thing with the floor, every sound in nature is reflected from the ground. But reflections from the ceiling are always unwanted anomalies.
Then again, if you use a directional speaker, ceiling slap isn't nearly so much a problem as it is with a speaker having less pattern control.
Previous Topic: Semi soundproof
Next Topic: Terrazzo Floors
Current Time: Fri Oct 23 04:04:39 CDT 2026
