Home » Audio » General » Loud "BANG" From Speakers
Re: Loud "BANG" From Speakers [message #70622 is a reply to message #70621] Sat, 24 December 2011 16:24 Go to previous messageGo to previous message
I have no doubt it's in the preamp. I remembered that you had narrowed it down to the preamp when I made my reply. I was just using the term "amp" generically. I've had lots of amps that did the same thing you're describing, both power amps and preamps, integrated and stand-alones. I've had prosound amps do it too, and when they do it with a few thousand watts, it makes a really good stress test for speakers. Twisted Evil
My point was really that I think the designer did not take the power loss situation into account when designing the delayed relay circuit. It probably uses a time constant to energize the relay which is shorted (to immediately de-energize the relay) when the power button is used to shut off the unit. If the switch isn't used, there is no shorting mechanism to kill the relay immediately, so it takes a while to de-energize, leaving the decaying power supply on the preamp circuits and making them unstable.
Lots of words just to say, yeah, probably gotta replace the preamp or get in there and redesign/rebuild the delayed relay circuit.
Previous Topic: Christmas Music for Ya'll
Next Topic: Gasket Material Recommended by Wayne P.
Current Time: Sat Oct 31 19:44:37 CDT 2026
