Home » Sponsored » Pi Speakers » JBL 2226H question: is this right?
Re: JBL 2226H question: is this right? [message #70618 is a reply to message #70602] Sat, 24 December 2011 11:38 Go to previous messageGo to previous message
haanjamin is currently offline  haanjamin
Did some more free air testing and both woofers start distorting at 23 volts at all frequencies I tested from 20-200HZ. So I have about 1/10th the power handling as I should have. Mad Since they distort at the same power input, would that be a sign of a knockoff recone job? I can't tell if the wire coming through the cone is flat or circular cross section because of too much black glue covering it.
One of them also has a rattle that starts at 6 volts that seems to go away when I block the cooling ports.
Recones should be able to fix all this, correct?
Previous Topic: The Alpha 10: less filling...sounds great!
Next Topic: mid horn box size?
Current Time: Wed Nov 04 19:32:08 CST 2026
