Home » Audio » Room Acoustics » What do you think about this Pi speaker layout?
Re: What do you think about this Pi speaker layout? [message #70535 is a reply to message #70532] Tue, 20 December 2011 23:44 Go to previous messageGo to previous message
Looks good. The subs flanking the mains will smooth the upper modal range, from ~80-200Hz. In order to do that, low-pass them around 90-120Hz with a gradual slope, second-order preferrably. Let the mains run full range. If there are no noticeable lower frequency modes under 80Hz, then that's all you need. But if you have problems at lower frequency, then you can place a couple subs in the opposite corners or somewhere else in the room, distant from the mains.
Previous Topic: Soundproof Windows
Next Topic: Does this actually work for soundproofing floors?
Current Time: Sat Sep 19 08:04:37 CDT 2026
