Home » Sponsored » Pi Speakers » 3pi with Sonido SCW-300
Re: 3pi with Sonido SCW-300 [message #70336 is a reply to message #69968] Wed, 30 November 2011 17:00 Go to previous messageGo to previous message
chakija is currently offline  chakija
Hi Wayne,
I took your advice and made original box proportionally larger so that inner volume is cca 137 liters. I applied distance between horn and upper edge and 285mm c2c for woofer and tweeter.
I decided to flush mount woofer because i like it that way Smile and i will fix alignment with crossover if needed. Material is MDF, front baffle 25mm and side are 19mm. Bracing in corners is 30x30mm and other two are 20x50mm made of hardwood. I made BR vent 105 because bass box pro (that i am simulating with) showed too big vent noise for smaller diameter. I will fine tune length later, but it will be around 70mm.
If you say this all is good enough, i will send cutting plans in workshop asap Very Happy
One more question... do you have any experience with motor run capacitors used in crossover instead of "audio grade" caps?
index.php?t=getfile&id=644&private=0
Previous Topic: Two PI tweeter question
Next Topic: 2pi tower crossover: mono or biwiring?
Current Time: Sun Nov 08 06:50:25 CST 2026
