Home » Sponsored » Pi Speakers » Driver Removal
Re: Driver Removal [message #70060 is a reply to message #69888] Tue, 08 November 2011 00:19 Go to previous messageGo to previous message
Wayne Parham wrote on Tue, 25 October 2011 09:44
I use an Allen wrench to lift the woofer (or horn) from the mounting holes. Remove all the screws, and put a decent size Allen wrench in the hole. Tilt until it catches and lift out, basically using the wrench as a prybar.
Worked well once the driver frame broke free from the butyl rubber gasket I made. Repair on the broken terminal on the crossover complete!
VIRIBUS MARI VICTORIA
Previous Topic: drivers are a couple hours away
Next Topic: 8 Pi plans please
Current Time: Sun Nov 29 17:19:34 CST 2026
