Home » Sponsored » Pi Speakers » Driver Removal
Re: Driver Removal [message #69889 is a reply to message #69888] Tue, 25 October 2011 11:32 Go to previous messageGo to previous message
It will depend on how tight the woofer is in the recessed cutout. I had a woofer that was very snug. I could not get it out. I made a handle that stretched across the face of the woofer to pull it out. For a 15 inch woofer, you would need a piece of wood that is about 17 or 18 inches long. I used a wood screw at each end of the wood, to screw through the woofer frame. Then the wood bar acts like a handle to pull the woofer out. Not sure if my description is clear.
Previous Topic: drivers are a couple hours away
Next Topic: 8 Pi plans please
Current Time: Sun Nov 29 17:19:43 CST 2026
