Home » Sponsored » Pi Speakers » What center channel speaker with 7π's?
Re: What center channel speaker with 7π's? [message #69834 is a reply to message #69831] Tue, 18 October 2011 22:01 Go to previous messageGo to previous message
petew wrote on Tue, 18 October 2011 18:44
Would the cornerhorns be compromised by my existing screen? It's about 2' off the wall. The framework is very open, and the screen itself is blackout fabric stapled to a lightweight wood frame.
That's fine, they'll work perfectly well.
petew wrote on Tue, 18 October 2011 18:58
Does the 7π kit include a waveguide or is the (gorgeous) wood waveguide required?
Kits come with a plastic horn/waveguide that can be enclosed in a small cabinet that sits on top of the midhorn. The wood horn is an upgrade option that is usually mounted on a cradle on top of the midhorn, so the curves of the horn are exposed.
http://lonestaraudiofest.com/2007/Photos/DSCN2937.JPG
Previous Topic: MDF
Next Topic: Painting MDF
Current Time: Sat Oct 24 19:54:27 CDT 2026
