Re: 4 Pi Home Theater Build [message #69820 is a reply to message #69808] Sun, 16 October 2011 20:59 Go to previous messageGo to previous message
Finally have the speaker's setup and started to break them in by playing a blues CD on repeat all day. Initial impression of the sound is very positive, they are significantly better than the Paradigm 9seMkIII's they are replacing. Here is a picture of them - and the flanking subs - in the room (screen is photoshopped to represent the size of the projected image, I left my screen in the states and am projecting on the blank wall and could not take a good photo showing the image and the speakers).
index.php?t=getfile&id=615&private=0
Right now I am running them with an Adcom GFP-555/GFA-555 combo with an el-cheapo Sony Bluray/SACD player as the source. The combo has way too much power as the volume knob is barely off 0 at normal listening levels. These are very sensitive speakers, easily demonstrated by the fact that the amp continues to play for nearly a minute after it is turned off. Shocked
I was unable to veneer them before my move and one of the speakers suffered very mild water-induced damage Rolling Eyes during the move (glue joint swelling requiring additional sanding to re-smooth the surface). Since I do not have any equipment in Cambodia, and finding that I absolutely hate MDF, I purchased oak vinyl laminate from Parts Express. Seems crazy to finish a thousand dollar speaker in vinyl, but the boxes will be rebuilt with baltic birch upon my retirement from the navy (less than 7 yrs). The enclosures have to survive at least two more military moves before I build new ones.
Based on initial listening the speakers meet my expectations and I expect to be using them for the next 20 years. I kept my paradigms as main speakers for over 15 - I do not make speaker changes often so I try to get the best bang for the buck.
Thanks again Wayne for your awesome support to the DIY community!
  • Attachment: IMG_0529.jpg
    (Size: 84.94KB, Downloaded 8656 times)
VIRIBUS MARI VICTORIA
Current Time: Sat Nov 21 19:48:09 CST 2026
