Home » Sponsored » Pi Speakers » AE Drivers
Re: AE Drivers [message #69814 is a reply to message #69812] Sat, 15 October 2011 13:53 Go to previous messageGo to previous message
coctostan is currently offline  coctostan
My models suggest that a TD10M would be less efficient than the Eminence Delta 10a spec'd by Wayne. This would require a crossover change for sure.
I'm curious if there are any upgrade drivers for the pi7 midhorn. I read your old midhorn thread and you mention the JBL 2012H, but it is no longer available. The JBL 2251J is very similar in spec's but uses a differential drive motor...and it is a 16 ohm driver. I'm curious if you would consider this a good fit for the horn if I were able to alter the crossover of the pi7 myself.
Previous Topic: One- Pi crossover tweeking.
Next Topic: Attention Everyone: Post Pictures of your 3pi speaker here
Current Time: Tue Sep 29 12:45:55 CDT 2026
