Home » Sponsored » Pi Speakers » 7pi cabinet plan request
Re: 7pi cabinet plan request [message #69795 is a reply to message #69793] Wed, 12 October 2011 01:01 Go to previous messageGo to previous message
jtavan is currently offline  jtavan
As it turns out, I do have calibrated audio test equipment and some experience using it, but unless I end up deviating from your recommended plans for some reason, I understand the sense in using a well-tuned existing network. I'll build stock networks.
Regarding midranges: I see that people have been using the JBL 2012 in the midrange horn, but you do not offer this unit in the 7pi kits. Are you no longer recommending this drive unit for the midrange horn? Additionally for the kits, I'm a little confused about the pricing model. You offer the wood tweeter horns for $700, but the 7pi kit (nominally including horn tweeter) is only $450, and the illustration shows it with your wood tweeter horn. Is this incorrect and it includes the H290 horn instead?
Thanks!
Previous Topic: crossovers
Next Topic: One- Pi crossover tweeking.
Current Time: Thu Nov 12 02:56:53 CST 2026
