gofar99 Messages: 2054 Registered: May 2010 Location: Southern Arizona
Hi Wayne, Right after you send some to Shane, would you send me a pair to ,........
BTW, I working on a write up on how dipoles work in rooms from a practical aspect. When I fiddled with the math on them it will drive you crazy as it indicates that they can't work at all most of the time, between direct and reflected sound particularly in the lower mids there is no hope. Fortunately, in real rooms they don't seem to exhibit the problems to that degree. Tall ESLs like I have tend to have an advantage over some conventional designs as they act a lot like a line source. There are smaller reflections off the ceiling and floor. With the curved radiating surface it most likely has an effect on how they react in rooms vs the math. Wayne might have the answer there. I suspect that they act more on average power at a closer distance than conventional ones as opposed to the near field aspects that were in earlier posts.
