Home » Sponsored » Pi Speakers » LAB12
Re: LAB12 [message #69759 is a reply to message #69758] Sat, 08 October 2011 19:07 Go to previous messageGo to previous message
You could build one up passively.
Or you could go cheap active, such as: Use the LF portion of a Behringer CX3400. About $100.00.
It will sum L&R out with variable low band x-o starting at 44 Hz. You could use the crossover in that to send a filtered signal to the satellite monitors, or you could go the blending route, and split your mon out to both the main amp and the CX3400. Done.
There's probably a lot of other options out there if you want to use your Hafler and not buy a plate amp (with built in x-o.) However, the Behringer is cheap and their recent build quality is good.
PS: Build up those 3 Pi kits and put them in your own studio.
Previous Topic: 3 Pi Crossover/Plans Question
Next Topic: crossovers
Current Time: Thu Nov 12 02:59:32 CST 2026
